mattyg1405
Well is wasnt going to start a build thread but since most of the parts came from people on this site i figured I'll post it up, if there's no interest so be it.
anyway the chassis started with was a 2000 Srx 700, the chassis is super clean, the only problem so far found was a outside stud went though the tunnel above the heat exchanger so I made up a patch quick and welded her in.
when I picked up the chassis it had a burned up number one cylinder and a broken rod, I found stock jetting in the carbs, a gutted air box, and a bender cold air kit.
Shortly after this I started riding my 09 nitro se and lost all interest in finishing the Srx, I used parts off of it to convert a grass sled to a trail sled and sell it in an effort to raise some funds.
i had mr viper build me a motor some time ago and am finally getting around to the actual build, yesterday I finished the welding work, stripped the engine bay and cleaned it up a bit more , took an entire inventory, and started ordering and posting in the wanted section for parts. All that's left right now is I'm looking for a track that's less than 1" in height stock pitch, preferably a fast track that I can run some studs in the middle I may keep them out of the outside of the track but we'll see as I start running the sled and see how it works I'm trying to make a great all around stock class sled to run some fun back yard races, and more low key events and maybe once in a while I'll pull her out when we ride far north on the flat stuff and rail some corners and show everyone how cool an old sled can be.
Here are some photos to see where I'm at;
