Another brass gear failure (overheating)
thefindian
The UP eh
Well I seen my second brass gear failure on a red head in the last 2 years my brothers sled 02 MM 700 kept over heating with cold heat exchangers we tried head gaskets first with no luck so we pulled in the 600 dollar running parts sled (00 sxr 700) we picked up last summer jerked the crankshaft out of it and bingo she is running again. what a shame everything else on the bad crank is in perfect condition I might have to send it down to Jeff and have a backup.
Could you fix mine while you're at it? Ha. I'm pretty sure I'm facing the same thing now. Who would rebuild the crank or whole motor?
Sent from my iPod touch using Tapatalk
Jeff at midwest crankshaft in green bay, wi is the guy I always use he is good at what he does as far as rebuilding the motor there not hard to do Im sure you could find someone in your area that likes to tinker in there garage and make a couple bucks.
