sloTJ
I took the center bolt out to try and remove it but will not budge. Any ideas? I'm trying to see how the backside of it looks. (Overheating)
Sent from my iPod touch using Tapatalk
roudyroy1
little bit of heat helped me, and tap around the out side of it lightly with a screwdriver and hammer to break the corrosion or locktite free. then work it lose.
sloTJ
Thanks I'll give that a try.
roudyroy1
be easy and just work at it, it will pop
sloTJ
just got it nice and hot, wiggled a flat head in around the edge of it and knocked on it/ pried on it then tried wiggling it around its not doing anything. frustrating.
hope someone did not epoxy it on.Mine just came off easy once bolt removed..don't heat it to hot and melt the impeller unless you are putting in a new one.
sloTJ
Yea with the bolt removed it makes no difference really.
A couple of bucks
If so, get out the BFH.you are putting in a new one.
dsc577
i just used a pair of pliers in both hands and worked it right off by grabbing the fins,
A couple of bucks
Could you possibly use the pull start for assistance.
sloTJ
This sounds possible but man is it stuck in there good. I started putting vice grips on the fins but worried of destroying em. But maybe has to be done.
sloTJ
I like this way of thinking. HAHa
sloTJ
and what about this. please do enlighten a dumb fella further. Like turning it over would help you think?
A couple of bucks
Clamping fins with vice grips and pull it over till the grips hit and stop turning abruptly. Or something like that. Sh!t, I'm just spitballing here.and what about this. please do enlighten a dumb fella further. Like turning it over would help you think?
roudyroy1
maybe a small 3 jaw puller with more heat? might break it but at est it wil be off lol
A couple of bucks
sloTJ
A dent puller!? Go big or go home they say
There was a problem with some of these. If they are over heading when hot it could be the brass gear is slipping an not circulating the water if you shut down and start up again it is ok look at the brass gear.
sloTJ
Yea I'm thinking that's what my problem is but I need to get the stupid impeller off to see! Then ill either have to buy a new motor or
find someone in my area to rebuild
If it is slipping it will be on the crank ont on the impeller it is easy to check pull case apart get one of those rubber oil filter wrench heat of the gear on the crank an try to move it.
