Did some more checking into my srx 600. I did a vaccum test on the middle cylinder. It just barely flickers the guage when pulling. The outer two make it really move. So I took carbs off and did the same test with the same results. Is there a crank seal that seperates the middle cylinder? Im getting closer. Im thinkin I have to pull the motor. I used 5psi of compressed air in to center intake boot. I could hear the air escape but I could not feel it anywhere. Thanks for your help
