Jean-Francois Aubin
Seems Yamaha for 2016 has different wide skis on the new VKproII and the European/Russian VK540.Wonder what the reason http://www.yamaha-motor.eu/se/erbjudanden/Snowmobiles 2016.aspx
where you have seen this new ski? i didnt find in you link.
low slung
Scroll down to bottom of page in link or use this link to see the skis on the VKproII http://yamaha-motor.ca/products/details.php?model=4634&group=SM&catId=23where you have seen this new ski? i didnt find in you link.
According to the Yamaha dealer the skis will not change for 2016 on the VK-540 IVSeems Yamaha for 2016 has different wide skis on the European/Russian VK-540 IV
low slung
Good to hear,thanks.According to the Yamaha dealer the skis will not change for 2016 on the VK-540 IV
Evaluation... ?
Can you write a detailed evaluation of these skis ?
			low slungJust finished installing a set of Yamaha blown plastic skis on my fathers 1996 ET-410II.
These are the skis that are new on the 2013 + 2014 European/Russian VK-540IV.
They give a lot more floation, way more stable, and remove about 12 lbs off the front nose compared to the OEM steel skis with skins.
they are 228 mm wide.
They really makes a difference hauling wood with two people on.
							low slung
A little increase in steering effort with these skis over the stock steel one(with skins).Much more stable on turns and off-camber terrain.Much more floatation in light snow(VK540,and ET410II suffer from all the weight over the nose,skis really help to fix this issue).They are pretty durable(Ran over some sharp rocks this past winter with only a light stratch,expected them to be ripped open).
			All Yamaha TSS sleds have the above problem.A little increase in steering effort with these skis over the stock steel one (with skins).
Much more floatation in light snow ( VK540 and ET410II suffer from all the weight over the nose, this wide skis really help to fix this issue ).
They are pretty durable ( Ran over some sharp rocks this past winter with only a light stratch, expected them to be ripped open ).
							low slung
Heres a video of them in action yesterday......https://www.youtube.com/watch?v=KA8NEOZ7v8I
			cback81
Hello, I love what you did with those vk skis on the enticer.  I'm trying to order all the parts for the mod but am having difficulty finding the p/n  8JH-23754-00-00 (collar x4)  The ones I can locate are all in Europe and shipping is over 50$!  Wondering if you know of any part #'s this will cross with?
Thank you for your help!
Corey
Corey
low slung
Pretty sure the 2004-2009 VK540III sold in the US market had plastic skis from the factory.I think they are the same part for both skis designs.
			cback81
I ended up paying dearly for them, that is ok, all said and done I'm at 310$.  I can live with that!  Thanks
			cback81
I finally got all of my parts in to install these on my 410, but there seems to be a fitment issue with the 8JH-23754-00-00 (collar x4).  they have an id of 5/16" and an od of 1/2".  The holes for the bolt to go through on the skis is 3/4".  So the bolt for the skis is 3/8" so it won't fit through the inside of the collars, and the collars are too small/sloppy to fit the hole in the skis.  Any help would be greatly appreciated!!!
Also, the "stopper" just rests in the cutout of the ski (after the plates are removed)? Did you fasten it in at all? Seems like if would rattle around a bit...
Pictures of your problem ?There seems to be a fitment issue with the 8JH-23754-00-00 (collar x4)
Since Yamaha uses the METRIC system on everything on the sled, I strongly recommend you get metric nuts and bolts.
cback81
I was just using standard measurements for reference only, (plus my measuring tape didn't have mm).  I did order the correct bolt that you used.  I also just ordered 8HR-F3754-00-00 (x4) which appear to be the correct collars I'm looking for.  I am still curious on the metal plate "stopper", does that just rest in the bottom of the ski or did you fasten it down somehow??  Thanks Again, Corey
			low slung
The metal plate fits in the ski(just rests there) and under the rubber block,same rubber block which is under the strut spindle.
							Jean-Francois Aubin
The metal plate fits in the ski(just rests there) and under the rubber block,same rubber block which is under the strut spindle.View attachment 61996
Hi low slung!, what is the model of the carbide do you used on your ski?
regards.
low slung
Stock yamaha 04 rx warrior carbides......or most yamaha plastic ski
carbides
			carbides
