98+01srx
Just curious if a viper cdi can be used on an 01 srx to run big rpm pipes. If possible is it trailable? I was told once that hauck sells the stock viper cdi as thier race boxes for srx and charges 500 dollars for it. Also wondering if the box with a 3 degree key is to much timing?
3g racing
The viper box will add 8 degrees of timing and a different carb set up will be needed as the power curve is completely different I probally would not run it w a 3 degree key or trail ride
98+01srx
So can you get a box that does not add timing but enables you to run more than 8500 rpm
Devilin AblueDress!
I could be wrong but I think the advanced timing is part of the recipe to run the higher RPM pipe effectively.
98+01srx
So is it possible to run 9200 rpm pipes on the trail then?
Works best for drags only by what I have read
YAMMIEGOD3:16
race only. no trails , and yes viper cdi are a yamaha race box. 3:16 (yammie tony)
I am running a viper box 01 srx stock motor and jetting on 105 octane. Have been riding that way for 300+ miles.
YAMMIEGOD3:16
105 octane is what keeping you riding. 3:16 (yammie tony)
