Mac
Viper cant pull more than 8000 RPM. Seems to run OK at idle. Heat on all three pipes. After a test pass we then check with infrared temp tester. Two pipes show 600 degrees or so and the third shows 325 degrees. Im dropping the PTO cylinder and the plug is wet and not burning. The other look fine. I installed a new OEM stator. Also swapped a CDI from a friends Viper. I have tried a different coil. And swapped the spark plug cap resister. Cylinder Compression is 152. I'm running out of ideas to test. What am I missing?
