powervalves installed up side down. 3:16
YAMMIEGOD3:16
webster n.y.
you guys ever see this. what danger is there if this happens,
1. catch a ring
2. stick and jam
3. break
4 will sled run ?
5. no rpm
i seen this happen, sled did run. 3:16 (yammie tony)
maybe a tad low on rpm but it wont make full power because the exh port will never be high enough. it wont hit the piston as the stop is in the cylinder. I have had them come in here like that,no engine damage just doesnt run the way it should.
