A couple of bucks
Does anyone have any personal experiance with putting these in a twin. Was wondering about a 96 XT and a 2001 SX600R.
The following is a c & p from BTV.
You can add the viper/srx reeds to the twin cylinder sleds without modifying anything, they drop right in and by themselves help to unblock the boost port even without the notch.
http://www.totallyamaha.net/forums/...stion-about-reed-notch?highlight=reed+stopper
A couple of bucks
I'd ask Scott, but I believe he has much more pressing issues at of late.
super1c
Super Moderator
I put these in my 98 600 twin xtc and they were perfect fit. I did the reed stopper notch also because the viper stoppers have a bit more meat on them and wasnt worried about them breaking. Not sure if it was a big improvement as i never rode sled before but it was sure snappy! And for a 600 hauled the mail after with a turk clutch set up. Here is my post http://www.totallyamaha.net/forums/threads/88678-My-ditch-banger-project!/page3
A couple of bucks
Are the SRX/Viper reeds different tension than the twins??
super1c
Super Moderator
Man not sure, Scott told me to run them so i did. I kinda left it at that at the time.
The pogo vmaxs have diff bolt pattern i believe
A couple of bucks
So a Pogo (96 XT6)twin is different than say.....a 98 XTC6 twin?
yes
pogo ones http://www.ebay.com/itm/Yamaha-1994...Parts_Accessories&hash=item5661798dfd&vxp=mtr
97-up twin same as the tipples http://www.ebay.com/itm/YAMAHA-SET-...Parts_Accessories&hash=item53f390892f&vxp=mtr
A couple of bucks
Sure as sh!t. Thanks for the heads-up. Whats the physical difference between the SRX/Viper cages and red head cages.
Srx reeds at little wider
A couple of bucks
Ok here's the update on the SX500R. Got the SRX/Viper reed blocks in there w/ a mild notching on the stoppers. It got rid of a very small amount of 0-1/4 throttle bog. But mid range and top end were fantastic. Noticeably better than before. Now what do I need to turn to eliminate that pesky bog off the line.I do have four of the .04 shims recommended in this post.....http://www.totallyamaha.net/forums/...-mod-question-with-picture?highlight=.04+clip
Or do you think it's a fuel screw adjustment?
A couple of bucks
ttt..
