YooperMike
So, I've read quite a few of the hang idle threads. I have an idea of what I need to do to begin trouble shooting it (adjust idle down/adjust fuel screws out), but nothing addressed one small thing that's happening with me, so here's what's going on. A month ago I got some SLP triples put on my 2000 MM (thanks Frank!). Everything was spot on, clutching, jetting, RPM's good, plugs looked great. After a few rides, I developed a hang idle, most noticeably yesterday. My warm idle is set at 1900+/-, and from idle up to WOT everything is awesome and if I keep it above engagement, I have no issues. When it comes back down, it hangs at 3000-3200, and if I blip the throttle while it's still hanging, i get a PING-PING-PING noise and no power, like TORS is kicking in or ?? After 10-30 seconds it will finally idle back down. So, early in my ride I popped the hood and found one of the plug caps loose, pushed it back on, rode a little, and it still did the same thing. The other thing I noticed is that the foam screen on the top of the airbox had lost a few 'chunks'. Could this be part of the problem? I have some panty-hose that I'm going to fix that with. Should I adjust my warm idle down first, and then if that doesn't work, adjust the fuel screws out 1/4 turn? New plug caps? I still don't quite understand the PINGING and power loss issue at the hang idle. Help!
