Rear skid re-assembly HELP!
brade07
Lifetime VIP Member
The Bush
I am rebuilding a 1985 phazer, i Have the skid mostly together, other than the rear swingarm (part that holds rear slide springs). I had to replace this part due to the old one having every shaft seized in place. I ordered shaft#2 from yamaha (shaft that holds rear upper idler and mounts to rear tunnel bracket, it appears to be a smooth shaft but on Yamahas diagrams it shows the idler being held to the shaft with a circlip??
Anybody have anyidea how this shaft fits in the swingarm, is there a collar im missing? or did I possibly get sent the wrong shaft? The length of the shaft is correct, the bolt holes are correct size and thread, but its too small of a diameter and is missing circlip grooves.
