Father in laws Hauck 780 viper, need info
you can try 2 big plastic washers on the bottom of the transfer rods and move the fra to the bottom setting and tighten up the limiters all the way, big rear shock loosen till there is 1inch of threads showing and loosen the front shock till the spring is has tension on to kept it from rattling, then the 2 front shocks loosen all the way till it is sitting flat on the ground
