Having fits with a misfiring mag cylinder on 2002 Vmax 600ERG. Carbs are clean, compression is good, however seems like there's intermittent spark only on mag. There's spark when plug is out of the cylinder however apparently that doesn't always mean there's spark when it's under compression.
On the Yamaha parts fiche, clutch and center coil part #s are different (8DF-82310-10-00) than the mag side coil (8DM-82310-30-00). I was hoping I could just swap one to test this issue.
Rode 110 miles and then all of a sudden the last 30 limped in on two. I've tried several rounds of brand new BR9ES plugs. The misfiring plug is hot and always brand new clean looking (not oily dirty).
I'm thinking bad coil or CDI. Any tests for either?
Matt
Matt
A couple of bucks
New plug caps??
New plug caps??
Thanks for the reminder - that's next on the to do list too. They are original. My only other thought would be a month or so ago my headlight harness shorted out on the pipe. The fuses blew properly but I wonder if that didn't damage something a little that's causing this too.
A couple of bucks
http://www.totallyamaha.net/forums/threads/87846-Spark-plug-boots-caps?highlight=Tb05ema
Read links within links.
Fantastic information - I got into links with more links and then into more links. Symptoms seem similar. I'll try to track some down ahead of the big one supposed to be coming today/tomorrow in NEMN. Thanks
A couple of bucks
Same problem I have w/ YOU TUBE. 3 hours later>>>>>>>>>>>>>>........................I got into links with more links and then into more links.
Changed spark plug caps and plugs, no luck. Must have a cylinder issue. Time to get dirty. Snowing like crazy here. Looks like I'm riding the 86 excel 3 this weekend!!!
A couple of bucks
Need to do compression test. Have you tried to move coils and see if problems follow the coil?
Besides the coil, caps, and verify the compression again as noted above, also take a look inside that cylinder and see what top of piston looks like, and is there any damage around the edges especially on exhaust side. If you have or can borrow an inspection camera, it will help greatly.
Other ideas:
Recheck, reclean carbs, it's not unheard of for them to plug up even if they were cleaned at the start of your season, or even just before your ride.
Check for air leaks at the rubber carb mounts and airbox boots, spray WD40 or carb/brake cleaner around the base gasket area of that cylinder while it's running and see if the engine changes pitch/rpm, indicating an air leak.
Other ideas:
See my original question. Are all the coils the same? The bad cylinder has a different part number than the center and clutch cylinders. Maybe the part number is different because the spark plug wire is longer.
I recleaned the carbs. No difference. Piston looks fine. Not leaking around boots. Tried all tests mentioned above. Only thing not yet done is take jug off which is what I'll do next. When I cleaned the carbs, that idle jet was plugged.
A couple of bucks
Yes..Are all the coils the same?
