mazdalavista
Hi! I live in Norway and prices are ginormous over here. Can anyone point me in a direction of a webshop or something where I can buy the parts in the picture below, or a good used set if anyone knows.
Dont know the technical term for them, but the valves are worn down at the sides, and the cables are shot. The control box is fine.
This is for a '98-'99 SRX 700
Devilin AblueDress!
I would be willing to bet if you posted a wanted add on here you would get some responses. For what its worth you say they are for a 98-99, they look like 98 to me. The 98 servo (control box) mounts on the front of the air box using a short cable. The 99 and newer servo (control box) mounts on the left side of the cowling using a long cable. ALL the power valves for SRX 700 98-02 will interchange. SRX 600 and Viper power valves will not work correctly in SRX 700...some web sites will try and tell you they are all the same, they are not.
mazdalavista
Thanks a million!
looks like I found a good set on ebay.
Btw its for a 98 with the short cables. Its for a friend of mine, not sure what year it was, until now
Thanks again
looks like I found a good set on ebay.Btw its for a 98 with the short cables. Its for a friend of mine, not sure what year it was, until now
Thanks again
