WarriorFrank
Does anybody know why the '97 SX700 would be so hard to pull the recoil? Ive had SRX's and we have a Viper and they all were easier to pull over. My '97 has 18,000km and runs like a champ!! It still beats most sleds on the lake but it is so hard to pull over. Is the recoil mechanism on an SRX or Viper larger in diameter to make it easier to pull? Will a recoil from an SRX or viper fit on to the '97 SX700?
Thank You for your help.
Frank
Frank
FJViper
The rope isn't dragging on anything or out of the holder is it?
shaggyzr2
I have an sx700 and an srx 700, the srx always seems easier to pull over.
Devilin AblueDress!
The older red heads did have a smaller diameter wheel. You might be able to frankenstine srx parts in there but the whole recoil wont fit. The newer (00/01+) red head have the large wheel and will bolt right on
roudyroy1
how tight is your belt deflection? that plays a big role in how hard it is.
Yep, when its colde out the sx is a beast to pull over. ,don't know why exactly but mine has always been that way. What I do is roll the clutch over by hand a few turns first then , go back and pull your guts out ..usually helps though,
WarriorFrank
Many thanks for the input guys. I will check the ride height on the belt as well as a recoil off of a newer SX.
WarriorFrank
Do I need to change the hub on the crank side too?
shaggyzr2
When look the part up on a Yam parts web site it shows that 97-06 used the same part.
roudyroy1
try using syn oil too, i find it makes it easier to start in cold weather
Vmaxin
I get lazy when its cold out. Put some pre mixed fuel right into the cylinder. Pull it over twice really slow just to loosen things up then 1 pull and boom. She's alive. Tried and tested to -40 celcius!
francis6667
mine was like that when the head gasket was toasted,i think the coolant in the cylinder???? after repleaced it ,it was easier to pull.
devinzz1
I go for the 1 foot on running board. Pull with one hand with all my weight technique. Even still. -30C, 140psi compression, cheap oil glazed cylinders ... Need i say more? One thing that ive done a couple times is shut the sled off with the choke and in the morning one good pull and shel fire up.
