Eng swap.... Help
3 in a row
Quebec
Hey troops. My 2000 sxr blew a crank bearing on the clutch side. I WILL build this motor. In the meen time I can pick up a 99 sxr 700 motor. What do I need to make this work in my 2000? Thx for ur time guys.
Nothing drop in and your good to go. Just make sure to bleed oil pump or u will need two cranks
If your sled has 2 bulbs for the headlight then you have a 300w stator, if you only have 1 bulb then its a 175w and you should be good to go!
