to make a long story short ive been trying for two years to get a clutch recipe dialed in and have not had good luck on top end. today put a 42 finish on my sled and hola. I should over rev using loaded up 8dn20's www primary and I didn't. so I now know something else is wrong. don't know what made be look at the heads but I notice 8dn-00. remind u this is a 2001. I remembered a post saying 2000 and up heads are 8dn-10. looking alittle further my cylinders say 8dn-00 also. so I at least know I have a 98 top half motor according to part #'s. is there any way to tell if my lower part is 2001. thanks for any help
the lower end doesn't match for the stator ...u can get a look at the cylinder number ...
the outside of the cylinder says 8dn-00 and what do u mean about the stator not matching?
you have the top end of the 98-99 ...98-99 stator doesn't fit in a 2000 up lower case ..it will but will need to be weld to place to pick up coil ...is it a 2000 ? or a 99 or 98 with the newer style headlight
its a 2001 with 8dn-00 heads and cylinders, hopefully that's all that's been switched.
it should perform almost the same ....ive seen 98 faster than 2000 and up ....
it performs well u just want what u pay for, would I use the 2001 jetting or 98
I would use 98 but ask other what they think since they are lower compression
thanks mod, anybody else with jetting help
Corey9965
I ran 01 jetting in my 99.
Corey9965
I just swapped sides with the bigger jet. On 01 it's cylinder 1. On99 it's cylinder 3.
thanks corey i'll give it a thought
have a chance to buy 2001 heads is it worth it to buy them and put them on even know I still have the 98-99 cylinders
mrviper700
VIP Lifetime Member
just check the squish clearance you have in the sled right now, and just mill your 98-99 heads to tighten it up some.
how much does it cost to mill heads, and when u say squish how do u check that, thanks
yamalars
Here you go:how much does it cost to mill heads, and when u say squish how do u check that, thanks
http://www.totallyamaha.net/forums/threads/12081-squishbands-and-modding-cylinder-heads
how much do u get to mill heads if I pay shipping both ways if I decide to do that after the season is over
mrviper700
VIP Lifetime Member
how much do u get do mill heads if I pay shipping both ways if I decide to do that after the season is over
at least:$6,678,987.99....no checks please.............lol
bout $60-70 for 3
bout $60-70 for 3
ok probably be getting a hold of u soon
