Hi,
I have a short viper 2003 er and i wonder if i can use 20T sprocket with the stock chain (68L)?
I belive its 22T stock now?!
Or how much can i gear it down with the stock chain?
s10mike
the 68 is the shorter of the two offered, so i would say it would work.
Agpetro
20t with work on it no problem. I have the same sled running a 20t which is the lowest you can go without having to get a shorter chain.
Ok, many thanks Agpetro.
Then it will be some clutch adjustment for me.
Agpetro
No problem thats what this site is for. With right clutching you're sled will pull like a mother!! Mine does.
