panterahead79
Hey all,
I'm in the process of installing a 2002 edge skid on my srx. I got the dimensions from http://www.jbshocks.com/edgemount.JPG. I hope they are correct. I have read that I should have went back a 1/2" more from the drive shaft. I did not see that info until I had already made the front brackets and installed them. They are a little closer to the steering loop then I would have liked. My mounting locations look similar to Johnnysrx's pictures in his write up. I made my brackets out of 3/16" steel stock. I couldn't find alum. stock that size.
I need some information on the 2002 edge rear setup. I can't seem to find much info on stock settings for this particular skid. I have info on 2001 and 2003 but they are a little different style than the 2002. I'm waiting on the front torque arm shaft I had to order bolt was broke off inside it. Hopefully it will be here today so I can make some progress tonight.
Here are the pics of what I have so far.
Inside of tunnel rear mount
Inside of tunnel rear mount new hole location.
Outside of tunnel rear mount new hole location.
The mounting plates I made for front torque arm.
New plates mocked up in tunnel.
Plates mounted in the tunnel I had to put back two rivets in backward cause of steering hoop
outside rivet locations
My shaft just showed up so hopefully I can get this together tonight. I will take more pictures as I go Thanks to all who posted the info on doing these swaps.
Ph
Ph
