98 vmax 500 doesnt run smooth
hessracing
Iron Mountain Michigan
Hey guys Im having trouble getting this thing dialed in getting fed up with it! stuck a bunch of money into the clutches vmax john set up still doesnt seem to preform the best doesnt seem to run as smooth as it should under a load seems very spuddery and not smooth the needles have 3 settings on them and 2 little white washers and are in the middle notch with the washers below them I have the air screws turned out 1 and 3/4 turns as it says on the belt gaurd I have a bender trail can on it as well the tor switch is bypassed will that make a differance in the way it runs? new plugs and caps as well.. if i didnt have bad luck id have none!!!
