hey guys hoping someone can help me out im putting a 2000 141 mtn max skid in a 2000sxr chassie . what I need is a accurate measurement of where the w arm bolts into the tunnel. like a given reference point to the center of the bolt in a rightangle to the tunnel any help would be great thanks in advance
should be 9 1/4" back from the driveshaft and down 6 3/8" from the inside top of the tunnel. referencing the driveshaft, your using the flat plane on the shaft measuring back from it.
just having the front mount wont work, so the rest of the needed measures are center to center from your new front hole: 13 3/8" to the center mount and from there c2c 15 1/2". down 5 3/16" and 7 5/8" respectfully. yamaha included provisional mount holes for center and rear. center being 5/8" lower and rear being 1 1/8" lower.
essentially your moving the three mount points somewhere in the neighborhood of 4 3/16, 4 3/16, and 5 3/16.
