warrior1100
hi i read that somewhare ,,,put piston of a 570 bearcat for a make a big bore kit in a srx ,,,anybody hear that before
Think it was maxx. perf. That used the cat pistons in there big bore kits. But u had to use a spacer plate with the kit to.
YAMMIEGOD3:16
never heard cat. alot with ski-doo. 3:16 (yammie tony)
warrior1100
which one piston BRP you here to make a big bore in a srx
vipersrxhouse
cat 550 pistons were the maxx performance kit
i happen to have a complete set up for one of these if any ones interested
warrior1100
hi viper,,,give me some detail ,,,i am interest
U will need a spacer plate with the cat pistons. I have 2 kits that use em.
warrior1100
hi guys , do have any parts number,,,any picture ,,,???
theres zero reason to go this route, youll need a spacer plate made up and then you can never remove the added deck clearance from the spacer.
if you want to do a 780, and you want it to run good and make good hp, your way better off using the std wiseco piston.
warrior1100
we have a bad experience with the aftermarket piston,,,, but if we don't have the choice we use Wiseco,,,,, if they have any piston on fit right there that was my preference
t-rav
I have an 835 big bore from bender that uses pistons wich are still made by bender it's forsale lol
warrior1100
how much you want for your kit ?
do you pass your srx on a dyno before ?
