I believe it's the black/white wire under the handlebar pad that goes to the kill switch but if you have an ohm metre you can double check that.If you tap into that one you should be good to go but make sure it's the right wire.Unplug the connector and follow it back to the right side throttle block,there's going to be 2 sets of wires coming from it,one set for the TORS (2 wires ) and the other for the kill switch,also 2 wires.
