no lights in SRX
srxtim26076
after trailering my 2000 SRX700 last night, It has now electrical power to the lights or guages. THe engine runs seems to run fine however. Is there a main fuse or relay?
could it be the wire harness is rubbed through under the motor. My friends 99 had wires rubbed through under the motor and his lights would flicker allot.
Also several units have had this issus with wire being worn under the motor.
Takes a bit of work to get it out from under there but its an easy fix, just time consuming.
Others will jump in and give suggestions too, this is the one that I know about.
Tod
its definately the wiring harness it rubs through between the radiator hose and the bulk head under the mag side carb
Mine did the same thing, It was really cold outside at the time....turned out to be the dialectric grease in the relay.......when it warmed up......it was fiine...
