Backwoods M Max
Anybody know what the distance from the drive axle to the front torque arm mount is on the 2000+ 141" mountain max sleds?
I'm putting an ez-ryde skid in this summer and need to work up a template. I wanted to use the front hole as my reference then I can go front and back from there. I need to be 12.5" back from the front axle (c2c) for the front hole then the rear hole is 26.223 back from there and dropped down 5.5" from the top of the tunnel.
It it looks like a straight forward install accept for having to remove some oem suspension mount plates because they are going to be overlapped. The rear mount is up in the tunnel so there are no drop brackets to mess with.
