Hyrax saver axel bolt & bearing
A couple of bucks
Ogle County Illinois USA
Hello all,
I have hyfax saver wheels & blocks(the top one in the picture)The bearing currently in it is a 6004 (I think). What bearing is the proper one & where can I find the correct axel bolt. ACE didn't have anything close to the I.D. Of the 6004 that's in it.
Does your set have the shouldered bushing that fits inside the wheel bearing, and up against the mounting block (you can see the "shoulder" part of the bushing in the pic you posted)? If so, that bushing should be sized (ID) properly for the "axle" bolt that threads into the block. The axle bolt would be a standard hardware store fastener, grade 8 would be best.
