LGUNN
Hi there! New member, as I picked up a 1991 enticer II 410. Looking to replace some simple things this summer. Any tips on parts purchases and maintenance would be great!
HANDSOME
put some stabile in the gas and run once in a while thru the summer. Clean the clutches with brake clean and compressed air. Spray parts that rust down with wd 40 and keep skis and track off the ground and cover it up from the sun.
I would say to replace the primary clutch spring as they tend to get weak over time.
check all wheels and bearings in undercarriage. replace/repack as nessasary. also clean and grease the jackshaft bearing and spedo bearing while you are at it.
replace the chain case oil as it is probably bad and re-tension the chain.
still running the old girl as last pic is from this season.
maintence/mods for last season was; new seat, sx venture skis installed, skid wheel bearings/wheels, spring sliders, repair/paint rack, front motor mounts, installed e-start, rockstoys starter saver, power supply and led headlamp kit.
LGUNN
Thanks guys, some great tips. Anyone know where to get an owners manual for this machine? Or digital copy?
LGUNN
Hey guys, starting to question the year. VIN 89X-002179. Can anyone tell what year it is?
if it is similar (other than colour) to the pics I posted, odds are it is a 1992 model year sled that was built in 1991. before that they where et340/400t or t/r with the leaf spring front ends.
the pics I posted are for a 1997 et410.
