A couple of bucks
Does anyone see a problem in running this air/fuel ratio guage on a 600 twin with no e-start/battery? One O2 sensor in each side of the Y pipe.
http://m.oreillyauto.com/mt/www.ore....oap?ck=Search_N0534_-1_-1&pt=N0534&ppt=C0134
you need a power supply for that one to work from what I have seen. you could use rockstoy's power supply from your headlamp as it has 2 rca's for heated shield that has stable 12v dc. used one similar to that on my xt to tune the carb and we had to run it from battery.
A couple of bucks
Do all of them need power or are there any mechanical ones than don't require power. Except for illumination.
A couple of bucks
Although I could just mount a battery in the engine compartment. Just till I have it dialed in.
A couple of bucks
You wouldn't have a link would ya. I GOOGLEd it and up popped a whole sh!t load of toys.you need a power supply for that one to work from what I have seen. you could use rockstoy's power supply
support@trailjamz.com this is the site for another product rock makes. he is a site advertiser on the 4 stroke side.
you can do it with the battery method, I just do not know how long it will last in the cold.
A couple of bucks
Do ya think I really need a 2 channel or would 1 o2 sensor be fine?
you could get away with one but 2 might be safer. all depends on how the airflow works. most twins are jetted the same for both cylinders in my experience.
you could get away with one but 2 might be safer. all depends on how the airflow works. most twins are jetted the same for both cylinders in my experience. just make sure you put it on the hotter running cylinder if running only one.
A couple of bucks
Do you remember what ya jetted down to?used one similar to that on my xt to tune the carb.
it was the xt350 in my sig, not a sled sry.
