Meistern13
I recently picked up a 01 700 triple sxr on a trade deal. It starts right up and runs mint. The issue is it will not rev over 2500-3000 rpms.
I have bypassed the TORS as listed in other posts here. It is still doing the same thing. I have unplugged the wires by the carbs. I have hooked them together with no changes. I have unhooked the wires at the throttle block and used the key to start and stop and nothing changes.
I am not sure how far I want to dig into this sled. ? Any suggestions for me? I read a lot about rubbed through wiring in the fourms is that something that would cause this issue?
Clutch issues? Where should I be looking?
I hope this is enough info for everyone!
It's irritating when you have fuel spark compression and it runs.! I hate Electronics !
Thanks in advance!
Nick
Edit * Youtube video of it running
https://www.youtube.com/watch?v=DRhqv6kPJTs
hope this helps
Thanks in advance!
Nick
hope this helps
Maim
Super Moderator
you did carefully try without a belt in case it was a drive train bearing that is seized?
A couple of bucks
Will it rev higher with 1/2 choke?
Meistern13
I removed the belt and it did the exact same thing!
Meistern13
No it just wants to die with any choke applied
shaggyzr2
Maybe a broken reed petal?
Meistern13
I don't think so? I have not wanted to dig in that far yet !
Here is the link to youtube to better help everyone understand
Thanks again,
Nick
Mysledblows
Sure sounds like a tors issue to me.
staggs65
X2, you connected the harness side to each other right, not the carb side?
Meistern13
I connected the harness side to each other. I also tried connecting the carb side back to itself as well.
Meistern13
I agree it is driving me nuts! There must be some other wire that tells the CDI to retard the timing? Other than the two wires at the carb
Nick
TORS issue for sure,slacken the throttle cable
Meistern13
TORS Is BYPASSED!!!!!!!!
Devilin AblueDress!
Not a 100% sure but I think if TORS switch is bad in the throttle end even bypassed at carbs wouldn't matter.
Try reaching your hand down there and see if it will rev higher manually.
Meistern13
I just adjusted the slack in the cable so there is about 1 inch of play at the carbs and it still does it !
Devilin AblueDress!
If the TORS switch is BAD in the throttle rocker you can have 10ft of slack in the cable and it will still do it. The TORS is a circuit that runs from CDI to carbs, to throttle, back to CDI. What TORS is supposed to do is identify when carb TORS switch is activated prior to throttle block switch. BAD switch = BAD signal. Does the pivot point slide back and forth?
Meistern13
Yes the throttle lever pivots in and out to hit the sensor!
Is there a way to bypass the throttle block
I tried just unplugging it but that didn't change anything
Can I jumper 2 or 3 wires or ground them out ?
Anyone have a schematic !
Thanks for all the help and suggestions
RB2001SRX700
Lifetime Member
I would find out what controls the tors switch. You said you bypassed the switch and it still does the same thing. I don't know what part of the system runs it but I would try and find out what does and where to look.
staggs65
try holding the throttle lever at the pivot with one hand so it doesn't rock on the switch and give it throttle with the other hand
Meistern13
I have tried that and it did not change anything
I disconnected the plug at the throttle block and tried jumping it back to itself and that didn't work either I also tried putting the terminals to ground as well with no luck
At this point I am thinking cdi box unless someone can get me a schematic for tors wiring loop
Thanks again
Nick
