So I bought this spare clutch that was for a 00-02 srx I was told. The problem is that it won't engage until 6400 rpm if I use 15,6 mm rollers. If I use 14,5 mm rollers it will engage @4900 rpm. With the same parts, with 15,6 mm rollers ( think) and same weights and spring, the set up will engage @ 4200-4300 on a another known "good" clutch. I have looked at the thing, and the only thing I can find is that the rollers are hard to turn around if I put 15 mm in it and almost impossible to turn if there are 15,6 mm in it. The cover seems to be a tall cover to me. So what's wrong here, the spider?
