Its out of sled, torn down to just the upper and lower case. The rewind, pump, and bracket has been removed. I can split it all the way on both sides but when I get to rewind side it gives me a fit....what am I not doing????
The stator bolt is off and the stator is on the shaft. Its stuck on shaft and won't pull off....any ideas?
INLINE4
- Jan 6, 2006
you must be talking about the flywheel..you need a puller, then the stator is underneath that
thats correct.Remove flywheel with a puller and then remove the stator,then you are ready to split the cases
Thanks guys..got it
