1999venture
Hi guys. I'm new here. Sorry in advance if I am posting in the wrong place.. Anyhow I have a 1999 Venture 500 XL with the 485 fan.. What's up with the liquid I am hearing about? I know about the triples (600 and 700) but not this engine. How many engines were there for the Venture? Thanks in advance.
There is a liquid VT 500. It used the same engine as the xtc/sx/sxr/dlx 500. There were 4 engines for the Venture in 1999, 500 fan, 500 liquid, 600 and 700 triples. In 1997-1998, the Venture 600 had an twin engine. Hope this helps.
1999venture
Thank you for clearing this up. So they dropped the 500 liquid twin in favour of the 600 twin? If so any idea why they would drop the 500 liquid (other than the power difference)?There is a liquid VT 500. It used the same engine as the xtc/sx/sxr/dlx 500. There were 4 engines for the Venture in 1999, 500 fan, 500 liquid, 600 and 700 triples. In 1997-1998, the Venture 600 had an twin engine. Hope this helps.
A couple of bucks
The only thing I can think of.....they both get the same MPGs. The 500 fanner gets fantastic gas mileage.So they dropped the 500 liquid twin in favour of the 600 twin? If so any idea why they would drop the 500 liquid?
1999venture
Really? I find mine to be a PIG sometimes. Then again.. Compared to my old GS 300.. It's a dream on fuel. Another question (only bought this sled last February and had 1 trip) is there any mods you can get for these sleds? Like power train wise? Thanks in advance.The 500 fanner gets fantastic gas mileage.
shaggyzr2
You could put a pipe on it. Not sure if they made one for the venture but I know that they made one for the phazer 500 which should be about the same thing.
1999venture
I was thinking that. And you might be correct because it should be about the same chassis, other than the Venture's chassis is retrofitted so that the 600 and 700 will slip right in. Engine mods should obviously be possible. Right?You could put a pipe on it. Not sure if they made one for the venture but I know that they made one for the phazer 500 which should be about the same thing.
shaggyzr2
Should be the same engine and chassis as the phazer 500.
1999venture
Yeah I was thinking the same thing. It should be possible. And the same with engine upgrades like carbs and pistons etc. just kicking skis hereYou could put a pipe on it. Not sure if they made one for the venture but I know that they made one for the phazer 500 which should be about the same thing.
The 500 and 600 liquid existed at the same time. The 500 was from from 1997 to 2001, and the 600 twin from 1997 to 1998. Both engines I believe were pretty much the same engine as in the 1994 vmax models, just made to fit the newer sx chassie.
shaggyzr2
You could also try some Boyesen or v force reeds.
1999venture
Okay Cool. I bet the performance difference is unbelievable between the 485 fan and 500 liquid.The 500 and 600 liquid existed at the same time. The 500 was from from 1997 to 2001, and the 600 twin from 1997 to 1998. Both engines I believe were pretty much the same engine as in the 1994 vmax models, just made to fit the newer sx chassie.
1999venture
That is true. I would obviously have to take the head off of the engine. Great time to check for wear and tear and replace any parts that need replacing. And put new performance pistons in just for the increase in power.
shaggyzr2
I really don't think there would be much of a difference in power between the 485 and 500. You'd probably be better off just sticking with the OEM pistons.
1999venture
I thought the liquid cooling would make a difference 0_0 anyway, you might be right about the pistons. The price difference should be HUGE though. And for probably longer lasting pistons.I really don't think there would be much of a difference in power between the 485 and 500. You'd probably be better off just sticking with the OEM pistons.
shaggyzr2
OEM pistons are worth the extra $. I had a phazer with a 485 and a vmax 500 liquid and there really wasn't much of a difference in power.
The fan is about 63-65 Hp and the liquid is about 87-93 hp, so there is quite a difference, and more the more rpm.
http://www.m-performance.com/Grafik/Dynobilder/yamaha/yamaha500/venture500-99/grafventure500-99.jpg
http://www.m-performance.com/Grafik/Dynobilder/yamaha/venturexl.jpg
1999venture
Ok cool. Thanks for the help. Btw just a tip. If you use yamalube use another oil. Yamalube is oil made by the lowest bidder. Garbage oil for more money. Just wanted to let everyone know.
1999venture
That is HUGE! It would be fun to put the liquid in a Phazer! lol and then MOD it. Well, they technically did *cough*Vmax*Cough*The fan is about 63 Hp and the liquid is about 87 hp, so there is quite a difference, and more the more rpm.
