roudyroy1
my 2001 sxr 700 has been stock for long enough.... time for some fun.
as the title says im looking to get it dialed in. i would like to start with re gearing it as i have herd about on these sleds. what gear ratio can be run with a 70 link chain?
Drop one tooth still works with stock chain 8df weights Stock 4.5 inner 3.6 outer and a 51/43 helix with green spring 70-80 deg
roudyroy1
aright thanks alot! what will that clutch set up do for me?
Puts rpm to close range pulls harded
roudyroy1
got a 21t top gear.... yet to put it in. so i assume those are 4.5 and 3.6 gram rivites? where do you guys pick up your clutch stuff? oem yamaha or after market????
OE yes if you want you can use gram scale and bolt and nuts.
roudyroy1
Okay, I'll stick with oem. Will that set up raise top end at all? And does engagement stay stock? By the way,thanks for all the help!
Have you done the head gasket mod, silencer mod and the reed stoppers? Thats damn near free HP on those sleds.
roudyroy1
I did reed spacers and am planning on boring the silencer... How much louder is it? I don't want to do the head gasket because of questionable fuel when ridding far north.
It only a few DBs louder then stock... it makes a nice crisp sound.
roudyroy1
Okay.... I think I'm going to bore it. Any one have a 51/43 helix?
roudyroy1
Will an oem yamaha helix work? I hear they aren't very aggressive. Just to be sure this won't kill my top end right? I'm pulling about 155kph right now and don't want to lose much if any.
Oe 8FA helix is 48-42
roudyroy1
does bender make a 51/43? did you lose top end from stock with this?
No should gain top end
roudyroy1
Any preferred brand of helix? Thanks for all the help by the way.
Aaen, Dalton, pioneer are what they say they are
roudyroy1
i do alittle off trail ridding as well. this set up wont make it boggy in the deep stuff will it? only a 121.Aaen, Dalton, pioneer are what they say they are
wheeliemaster92
you can do the head gasket mod just do two layers instead of three and you are still in a very safe place for even questionable fuel cause u only would be taking out 10 thousands of an inch so you will have no concern with questionable fuel. so i would definately do it and boring the silencer sounds amazing too and gives you a few hp now where did you get your reed spacers from and how much did you get them for?
roudyroy1
We were out in -40 last year, and when your 200km from a large town you don't know what your getting for fuel. so the head gasket and jets will stay stock for peace of mind. Silencer will be done, I'm just worried about how loud it will be. I made my own reed spacers out of aluminum plate. Just traced the gasket and scrolled it out with a jig saw. Took a while to do. Royal distributing sells them.
