SX Viper Dialing in
Also found
50/34-.46
54/40-.46
54/38-.46
I do have a Heel Clicker hc-10 kit on its way
Also the red/black spring is a 140/240
The red/blue is 140/200 is that the same as you're thinking?
which one is in your stock team secondary? i ran the black/red spring in my set up with a almond red up front. I think running the heel clicker set up that the red/blue will be able to work for you but may need the black/red if it doesnt hold the belt. Thats the bad part about the team setups, you cant adjust anything. Always have to change springs. Also i would just stick to the dual angle, full progressive usually is harder to work with and when i used them i kept reverting back to the just straight dual angles
i would defiantly try that 50-34 .46 and use that with the spring you have in it. Give it a shot. i think that is going to work really good with the heel clickers
