I'm looking to order a helicoil set to fix the stripped threads of a couple of reed cage bolt hole but my sleds are still in storage and can't remember the size.Can someone get the bolt size for me so I can order the correct inserts? This is for an SRX.
6mm x 1.00
This is very common alot of times instead of heli coil the holes I will just use longer socket head(aalen) bolts in them go 2mm longer and there will be good threads, its up to you.
Backwoods M Max
The bolts that came with my vForce reeds were too short to hold the coils on and stripped the first 2 threads off (it was all they were grabbing). On a red head the holes are open and I got long bolts that the tip is a few threads sticking out, I know I wond have any problems that way.
6mm x 1.00
Yeah I already had used longer bolts in them but the threads were kind of screwed up further in too so I tapped them to standard thread but it's a pain in the arse to keep swapping back and forth between standard and metric wrenches and keeping the bolts separate.
