1995 Phazer 2 torque specs
roudyroy1
ontario GTA
I am doing a track swap on a Phazer 2 and need to know the torque on the suspension mounting bolts, big nut on the drive axle, chain case mounting bolts and cover bolts. If anyone could give me a hand or send me a few pages out of a shop manual that would be great.
Suspension mounting bolts - 50 FT/LBS, Drive shaft nut - 61 FT/LBS, Chain housing and caliper body - 35 FT/LBS, Chain case cover mounting bolts 7.2 FT/LBS.
Here is the general torque specs from the TECH section.
Bolt Assembly Torque (ft-lb)
The torque values in the table are based on the use of lubricated threads.
Size (mm)
Grade 8.8 Iron
Grade 10.9 Iron
Grade 12.9 Iron
Aluminum
6
5
10
9
4
7
9
14
18
7
8
17
25
29
14
10
33
50
50
25
12
60
85
95
40
14
90
133
145
65
16
140
200
210
100
18
200
285
290
135
20
290
400
