roudyroy1
I am doing a track swap on a Phazer 2 and need to know the torque on the suspension mounting bolts, big nut on the drive axle, chain case mounting bolts and cover bolts. If anyone could give me a hand or send me a few pages out of a shop manual that would be great.
roudyroy1
Still need them.... TTT
sleddineinar
I have a manual somewhere, I'll look for it.
roudyroy1
Thanks!!!
Suspension mounting bolts - 50 FT/LBS, Drive shaft nut - 61 FT/LBS, Chain housing and caliper body - 35 FT/LBS, Chain case cover mounting bolts 7.2 FT/LBS.
roudyroy1
Thanks!!!
roudyroy1
Thanks!!!
No problem... CHEERS!
roudyroy1
What about the small cross shaft up in the tunnel with the 12mm bolts? And the upper sprocket nut and lower sprocket bolt? That should be all I need.
A couple of bucks
Here is the general torque specs from the TECH section.
[TABLE="width: 446"]
[TR]
[TD="colspan: 5"]Bolt Assembly Torque (ft-lb)
The torque values in the table are based on the use of lubricated threads.
[/TD]
[/TR]
[TR]
[TD]Size (mm)
[/TD]
[TD]Grade 8.8 Iron
[/TD]
[TD]Grade 10.9 Iron
[/TD]
[TD]Grade 12.9 Iron
[/TD]
[TD]Aluminum
[/TD]
[/TR]
[TR]
[TD]6
[/TD]
[TD] 5
[/TD]
[TD] 10
[/TD]
[TD] 9
[/TD]
[TD] 4
[/TD]
[/TR]
[TR]
[TD]7
[/TD]
[TD] 9
[/TD]
[TD] 14
[/TD]
[TD] 18
[/TD]
[TD] 7
[/TD]
[/TR]
[TR]
[TD]8
[/TD]
[TD] 17
[/TD]
[TD] 25
[/TD]
[TD] 29
[/TD]
[TD] 14
[/TD]
[/TR]
[TR]
[TD]10
[/TD]
[TD] 33
[/TD]
[TD] 50
[/TD]
[TD] 50
[/TD]
[TD] 25
[/TD]
[/TR]
[TR]
[TD]12
[/TD]
[TD] 60
[/TD]
[TD] 85
[/TD]
[TD] 95
[/TD]
[TD] 40
[/TD]
[/TR]
[TR]
[TD]14
[/TD]
[TD] 90
[/TD]
[TD]133
[/TD]
[TD]145
[/TD]
[TD] 65
[/TD]
[/TR]
[TR]
[TD]16
[/TD]
[TD]140
[/TD]
[TD]200
[/TD]
[TD]210
[/TD]
[TD]100
[/TD]
[/TR]
[TR]
[TD]18
[/TD]
[TD]200
[/TD]
[TD]285
[/TD]
[TD]290
[/TD]
[TD]135
[/TD]
[/TR]
[TR]
[TD]20
[/TD]
[TD]290
[/TD]
[TD]400
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[/TR]
[/TABLE]
[TR]
[/TD]
[/TR]
[TR]
[TD]Size (mm)
[/TD]
[TD]Grade 8.8 Iron
[/TD]
[TD]Grade 10.9 Iron
[/TD]
[TD]Grade 12.9 Iron
[/TD]
[TD]Aluminum
[/TD]
[/TR]
[TR]
[TD]6
[/TD]
[TD] 5
[/TD]
[TD] 10
[/TD]
[TD] 9
[/TD]
[TD] 4
[/TD]
[/TR]
[TR]
[TD]7
[/TD]
[TD] 9
[/TD]
[TD] 14
[/TD]
[TD] 18
[/TD]
[TD] 7
[/TD]
[/TR]
[TR]
[TD]8
[/TD]
[TD] 17
[/TD]
[TD] 25
[/TD]
[TD] 29
[/TD]
[TD] 14
[/TD]
[/TR]
[TR]
[TD]10
[/TD]
[TD] 33
[/TD]
[TD] 50
[/TD]
[TD] 50
[/TD]
[TD] 25
[/TD]
[/TR]
[TR]
[TD]12
[/TD]
[TD] 60
[/TD]
[TD] 85
[/TD]
[TD] 95
[/TD]
[TD] 40
[/TD]
[/TR]
[TR]
[TD]14
[/TD]
[TD] 90
[/TD]
[TD]133
[/TD]
[TD]145
[/TD]
[TD] 65
[/TD]
[/TR]
[TR]
[TD]16
[/TD]
[TD]140
[/TD]
[TD]200
[/TD]
[TD]210
[/TD]
[TD]100
[/TD]
[/TR]
[TR]
[TD]18
[/TD]
[TD]200
[/TD]
[TD]285
[/TD]
[TD]290
[/TD]
[TD]135
[/TD]
[/TR]
[TR]
[TD]20
[/TD]
[TD]290
[/TD]
[TD]400
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[/TR]
[/TABLE]
