Rebmo
I have the suspension out and have replaced all the wheels and bearings/bushings that were in need of attention. I was able to press out all the axle/wheels without any issues. I noticed that extra grease fittings had been added by the PO who really took care of this sled that I aquired 4 years back.
I replaced the slides and greased all the bushings and greased all the zerks. The only remaining area I now noticed needing attention are the plastic shim/seals (broken) on each end of the wheels on the control arms. I notice the plastic pushing out in pieces when I was greasing the rear pivot arm zerk. So I started to look over what it would take to replace these plastic bushings and am not sure my press can handle removing the wheels? With the control rods and rear pivot arm all attached I need some advice on how to press the wheels off. What is also strange is that there are no C-clips retaining these wheels?
Any advice on how to press these wheels off would be greatly appreciated. Maybe I need to take the rear pivot arm assembly in to a shop with a bigger press or can I build a 2x4 or 2x8 frame under my press cylinder, or?? I can't see a way to get the assembly under the press to get the wheels off? Plenty of grease in there now, but as long as the skid's out I'd like to replace the plastic bushings, appreciate some help from those that have done this.
TIA Reb
TIA Reb
