Turboing
regert
Millgrove, Ontario
I've googled and searched for info on turboing a SRX, only thing I found is a guy selling a viper turboed motor in a old 77 srx chassis. Anyone have any info on turboing a 2 smoke any info would be usefull.
IE: size of turbo, fuel, timing, psi to run, any info please.
I have a 98 srx700 that trail ported and crank is welded, think it should hold 6pis.
Thank you
SRXtreme back in the day turboed one. Made over 200hp. Hes since moved to the 4stroke side. Theres been a few turbo srxs ive seen on the internet. Alot more twins or single pipe triple setups.
My brother and I are looking into putting a turbo on a viper or an srx. I was thinking the same turbo there using on the 800 cats and skidoos
A friend of mine turboed his sxr and it was gnarly...only thing he hasn't adressd is it literally suckes the float bowls dry on a good long pull. She likes a fuel! Im pretty sure He used a seadoo turbo.
Actually he pulled the whole setup out and put in an rx1 with turbo in the sx chassis the thing is a beast cant wait to try it out. ill ask him if he wants to sell and pm you if you want. Hes not on ty unfortunately
Jacks haft wouldn't make sense, must have had a modded flywheel with a pulley attached to take a belt or somthing
