regert
I've googled and searched for info on turboing a SRX, only thing I found is a guy selling a viper turboed motor in a old 77 srx chassis. Anyone have any info on turboing a 2 smoke any info would be usefull.
IE: size of turbo, fuel, timing, psi to run, any info please.
I have a 98 srx700 that trail ported and crank is welded, think it should hold 6pis.
Thank you
Thank you
devinzz1
SRXtreme back in the day turboed one. Made over 200hp. Hes since moved to the 4stroke side. Theres been a few turbo srxs ive seen on the internet. Alot more twins or single pipe triple setups.
regert
Thank you I'll see if I can message him, any other info out there guys?
Cooper0809
That 77 is sweet! Did you see that on kijiji? I think there's a video of that thing too!
regert
Ya saw it on kijiji, looks like the intack is made of PVC pipe. it must rip. if I had the cash I'd buy it
383stroker
My brother and I are looking into putting a turbo on a viper or an srx. I was thinking the same turbo there using on the 800 cats and skidoos
J
jaydougempire
Guest
A friend of mine turboed his sxr and it was gnarly...only thing he hasn't adressd is it literally suckes the float bowls dry on a good long pull. She likes a fuel! Im pretty sure He used a seadoo turbo.
regert
do you know if he still has the sled or even the parts he used on the build.is he on TY
J
jaydougempire
Guest
Actually he pulled the whole setup out and put in an rx1 with turbo in the sx chassis the thing is a beast cant wait to try it out. ill ask him if he wants to sell and pm you if you want. Hes not on ty unfortunately
regert
ok that sounds good, thank you.
J
jaydougempire
Guest
Hey so I was wrong he used a supercharger from a seadoo not a turbo im an idiot...I haven't been able to get ahold of him but I'll keep trying. I did find a supercharger on eBay cheap with no reserve here's the link.
http://pages.ebay.com/link/?nav=item.view&alt=web&id=291285364325
regert
wonder how he ran it? off the jack shaft some how?
J
jaydougempire
Guest
I'll find out
roudyroy1
Jacks haft wouldn't make sense, must have had a modded flywheel with a pulley attached to take a belt or somthing
