97sx 700 with vforce 3 reeds need jetting and needle for psi triples
chrisx97
jackson
hey everyone I have a 97sx and it has currently vforce 3 reeds and slp can stock pipe I just bought a set of psi triple pipes and cans and need needle and jet setting with reeds and pipes together, also would like to know what kind of clutching I should do to the sled I am 180ibs if that helps. thanks if you can help it would be greatly appreciated.
I just installed some psi triples on my sx 700. Curently running 150mains. Stock 45 pilots. Needles at 3.5/4/3.5. Seems to be running good. Havrnt had alot of miles or snow to get it 100%. Havent done any clutching yet unfortunatly.
ok thanks a lot that helps a lot let me know if anything changes and what kind of clutching you do.
heres your jetting specs for those pipes = fuel screws out to 3 turns--needles set at 3rd/4th/4th/ pos. mains are: 142.5 across the board. those are for 0- 2000 ft elev. I know it seems funny that you jet down but that is a tried and true jetting spec with those pipes! As for clutching try: 8ca's with a small aluminum rivet in both holes, 52/ 42 helix if you can find a psi green spring ,use it, if not run the stock one with 2 shims . 60* turn on sec.. youll want to shift out at 9200 rpm for maximum performance! 8-cr's also work well with this setup!
