85 phazer carb specs
85phaznut
ontario
i have my 85 carbs torn apart trying to find out if the jets are stock or not does anybody have a diagram or exploded view of the carbs that show what and where each jet is? in the tech section i seen the float is supposed to be 12mm + or - 1, where do i measure from? and do i measure when its right side up or upsidedown?
also i bought a used motor from a guy on a local buy n sell site with the carbs (this motor was from a 1992). when i picked it up he had phazer and exciter parts everywhere (he didnt have a clue what was what) on the top of the carbs from my phazer there is two stamps on the throttle side is 80L and on the opposite is 8VO 02, and on the carbs that came with the used motor is 80L and 8vO 03. what do those me
any information would be hugely appreciated.
Can I get a copy of that manual? I have a '92 that I'm trying to clean the carbs and fix a tach drive oil leak on. Thanks in advance, Justin. justingj at gmail.com
