roudyroy1
my mm600 is 1998 twin. my vmax700sx is 1997.
I thought you were putting a triple into another triple frame. That makes more sense about the mount now.
nelsonhouse
I have the redhead in the mm. The wiring harness is different. is there a way to make this work.
Use the wiring harness from the sx redhead chassis, including CDI, etc. With the harness out and exposed, it's a good time to check for damage/rub thru's.
nelsonhouse
Ok. I ordered a wiring harness. I'll put that in there when the post office opens up. The redhead bolted right in after rear motor mounts were moved to the right spots.
