J
jaydougempire
Guest
Could someone give me the exact proven procedure to repairing powervalves?
Yep I have all the neccessary tools. Lathe, mill welder etc. Do you have pics before and after? Its anodized aluminum correct? Are you replacing any of the material that you machine off in anyway? What's the ss bolt for?To do them properly you'd need a lathe... Some guys sleeve them but I'm not sure how they do that. To do it on the lathe you have to remove the tip of the valve, drill and tap hole, then insert a SS bolt, then drill and cut you slot in the tip of the valve. Pretty simple to do if you have a lathe or access to one.
