Power valves
joejammer
I have a 98 srx 700 i would like to try to energize the servos to adjust the power valves. On mine there are 4 wires black and red , yellow and blue, white and black, black and yellow. The first color is the wire the second is the stripe. There is also a single wire going to the servos that is white with a red stripe
If you start sled and turn idle down to under 900 rpm the servo should fully open...way easier than hooking up to a battery
