Shrader
I have an 02 viper that he speedo does not work on, it just shoes 0 all the time. I have checked continuity from the harness to the speedo, and all wires are good (or at least have continuity), the previous owner installed a new sensor, and left the old one with the sled, which i also tried. I have an extra speedo unit from an rx1, and that does the same thing. There is power, and ground at the sensor harness also. Is there a way to test the speed sensor itself? as in, is there a way to ohm it? drive bearings, and reluctor wheel are also in perfect shape. Any idea what might be wrong?
