01sxr700
Is it the same one that keeps leaking, have any of the jugs been replaced with remans? Got a reman back once that was .009" shorter than stock so head would not tighten properly on that cylinder. Put a straight edge across the top of the engine to check.
sloTJ
I'm not totally sure if the motor has ever been apart ever. I bought the sled years back with just under 10k miles and ran well. It began overheating last season. I pulled the head and found the one gasket was "washed" so I replaced it. I also took the waterpump cover off an replaced the impeller. Thought I fixed it but started to overheat again so I took it in. Turns out the heat exchanger has a crack, my front exchanger is loose! and the old gaskets are bad and leaking, and the water pump was leaking because the mechanical seal has to be put I correctly with a new one. I didn't know this... They fixed the waterpump but I couldn't afford more so I have to do the rest myself. I already pulled the left exchanger and have to pick one up for $50 and rivet on and have yet to hopefully correctly do all gaskets which are crazy expensive!! Ugh /of rant.
sloTJ
8 ft lbs the first time around.
17 ft lbs the second time around.
Couple of bucks seems to always be a help on everyone's thread! Thanks.
sloTJ
Sorry to hear about your problems but at least get the sled off of it's side. Hate to see it like that. I would do what ever one has said about the head gaskets. I just did a top end on mine and got all the info off the tech pages. Good Luck.
It should be off its side sometime this season. Maybe ill even be able to actually ride this snowmobile for once. Is that what they are supposed to be used for?? I can't remember... Did you use copper spray on the gaskets?
sloTJ
http://www.totallyamaha.net/forums/showthread.php?t=94216 Here's a thread that explains all of the previous problems and stuff gone through with my sx... if you want to do some reading. Thanks everybody.
01sxr700
So when you pull the head off run a straight edge across it. look for gap anywhere between the two. try using some feeler gauges.
dsc577
i threw used ones on mine and only used a single layer,lightly put a couple coats of copper on,let it dry then sprayed em with permatex adhesive,been holding up fine
01sxr700
That usually works fine as long as everything is true.
sloTJ
spray the head surface and the tops of the cylinders off with brake clean to remove oil and antifreeze, blow dry with compressed air.
on the headgaskets, clean those as well with brake clean, wipe dry. When you use the copper kote spray you just want to dust them not paint them with a thick layer, just dust them in light coats to cover the surface, let dry overnight and flip them over and repeat, let dry well before installing them and then torq it all down like posted. dont touch the surface with your fingers, hold them via the tabs on the ends.
never had any leak problems this way.
This look good? one coat both sides so far
![GOPR0044[1].jpg GOPR0044[1].jpg](https://totallyamaha.net/data/attachments/28/28372-7d47311d1effb00a61353fd343d06cc8.jpg?hash=fUcxHR7_sA)
A couple of bucks
sloTJ
Should I do another coat you think?
sloTJ
sloTJ
Did you get the coolant system bled out?
roudyroy1
Sounds like it's the brass gear on the water pump slipping
rruser
Sorry if this has been done already, but have you tested or replaced the thermostat?
shaggyzr2
Those don't have thermostats.
rruser
sloTJ
I added more coolant and was able to ride it for about 20 min and no light! All exchangers were warm. It's done this before tho too. Ill have to drive it more and see
sloTJ
I just rode it awhile today (1.5 hrs), no light ever! This triple's making it to at least 11k miles!
