pete72
i have a comet clutch on my 87 exciter and for the life of me can't find a model # not sure if its a 102 or 108 etc. how does one tell?????????
it says right on the front cover plate, its stamped in the metal on the 102, the cover plate is differnt on the 108,its aluminum,the diameter of the clutch is also bigger.
Post a pic of what you have.
pete72
so this must be a 108 then? no numbers and aluminum cover. its pretty dirty but seems to engage ok.bushing between sheaves is a bit rusty and cleaned the best i could with fine sandpaper. has a moroon or dull red spring in it. engages around 3700-3800. what clean up/work can be done with the clutch on the sled? what about lube? sleds got some motor work done bored but not sure how far,twin psi pipes 130 psi in each hole . which puller do i need if i need to remove
pete72
yep, 108
you might be able to get puller from like dennis kirk
I would take it off and bead blast that whole clutch and then see what arms are in it and spring then make some adjustments to suit your hopped up engine, I would think youd need around 400004200rpm engagement speed and then whatever rpm the pipes run at for your shift speed. i have all the comet chearts to match the springs with weights etc, so I can help when your ready to put it back togehter, it needs a good cleaning for sure.
no lube...
no lube...
Vmax540
Throttle Junkie35
Piped exciters like 5,000 rpm engagement.
pete72
wow thats pretty high i would say. i would never have it like that for a trail riding sled. no lake racer herePiped exciters like 5,000 rpm engagement.
pete72
thanks mrviper700
Throttle Junkie35
Not really,I have mine set up that way using a Yami YXR clutch. It doesnt engage hard and works great. I'd have to check my notes but I think PSI recommends 4800 for the twin pipes. Low rpm engagement makes those pipes turds and useless.
Throttle Junkie35
Just checked my notes and PSI recommends a 40-4,100 engagement RPM. Honestly, I really like a 5,000 go number as its a lot of fun.
pete72
so what i have is pretty close and would think it would be fine for what i need. just trying to get everything as good as i can before snow shows up. come on snow!!!!!!!!!! wooo-hooooJust checked my notes and PSI recommends a 40-4,100 engagement RPM. Honestly, I really like a 5,000 go number as its a lot of fun.
