Srx handle bar ?s
yamahasrxman
flushing michigan
I'm looking to put a set of apex handle bars on my srx. Since the throttle assembly doesn't come apart will the apex one work?I need to know if the t.o.r.s will still work or if I will have to bypass it.An correct me if I'm wrong but will the 03 viper mountain throttle cables work for my rise?or would I be better off using some mountain max cables.
Apex bars will work. Few things. If you can get the 06 bars as the ends come off. People complained that they wanted heat all the way to the end of the bar so in 07 they are all one piece. Or you can perform surgery on your throttle block and make it work but I didn't want to do that. Also if you can find a 04 viper block it is 2 pieces an that will work also just need new 2 into 1 throttle oil cable. 03 mountain cables will work for this mod. I did this to both my vipers and love it. Do a search apex bars on viper, tons of posts. Will work the same on srx
