Yup, been busy reading the past few days and did pick up on the dual cable. Was also out looking over both sleds much of yesterday seeing what else was different between the pair. Looks like both skids are also different from each other, and the 05 has a rear heat ex-changer where the 02 does not. Skinny little 5.5" skis on the 02 while the 05 has 7" skis up front. They're both pretty clean sleds but I'm really liking to 05 so that one will be mine while the red one will be my wife's sled. I'll likely upgrade the skis on the 02, add the torque arm kit, and maybe a 4x4 pipe with a new silencer. Also wondering if it's necessary to move the needles up to #4 in the carb's as I'm at higher elevation where the sleds are ridden at 4000' feet to 6000' on average. Less air density here probably equates to them running richer than on the flats, but I'll still be looking into that.
The 05 will likely be piped, clutched and jetted for some more power, and I'll add reverse to it since that will surely save my back which isn't what it used to be. Most of my riding will be in the meadows and play areas this year as my wife and kids are pretty new to all of this. They'll also be used for a bit of ditch banging along the highways and taken out for a few trail rides this year. I'm still a speed junkie and love bring the front end up so I'll also be reading to see how I can get the weight transfer right on the blue sled.
Great forum you guys have here. I'll be reading more in hopes of learning lots about these engines and skids. I've always been a Yamaha guy and know I always will be.
